CARLSON EXPLORER 600+ speed and keyboard
(@billvhill)
I purchased a Carlson Explorer 600+ with SurvCE Version 2.61. I connected it to my Topcon Hiper Lite+ GPS unit. Every time I located a point the hour glass appeared and it takes about 3 to 5 seconds to record the shot. Is this normal? I have an old TDS Ranger, I believe its a 200 and it records the shot in about half of a second, Also the keyboard keys are hard to press and slow down progress when entering a point description. The Ranger has soft keys that can be keyed in rapidly. I don't know if I should sell the unit or be patient with it. I used a Lieca collector with the same type of keys and never really liked it. I wonder if all the new units are switching to that type of key board or if the ranger is still using the same soft key keyboard.
Posted : February 5, 2014 2:32 pm
(@john-harmon)
The Carlson has a terrible keys. Alomst have to use a eraser end of a pencil to push.
Posted : February 5, 2014 3:25 pm
(@kevin-lindsey)
http://www.carlsonsw.com/support/knowledge-base/?action=display_topic&topic_id=551
This should fix it.
Posted : February 5, 2014 4:29 pm
(@russ455)
Did you try a cable as well as a Bluetooth connection? are the both very slow?
Posted : February 10, 2014 6:18 am
