Ashtech Solutions 2.6 - Win 7 64 bit
Guest
I asked this question [msg=37767]Here[/msg] a while back but now add 64 bit. Previously used in Visat 32 bit I am now running 64 bit Win 7 Pro.
I want it for my Locus L1 units that get an odd work out.
Are there any users using this combination please.
I am also running (once its installed) Spectrum Survey L1 for my Stratus units.
regards
Richard
Posted : June 5, 2011 1:32 am
(@derek-g-graham-ols-olip)
Maybe Phil Stevenson could give you a 'leg up' ?
PStevenson@ashtech.com
Derek
Posted : June 5, 2011 10:07 am
I don't use that software, BUT my guess is you will be OK, I haven't come across any software that won't run, some of it only in the XP virtual machine which may be what you have to do. Even though a 64 bit software, the XP virtual PC runs in a 32 bit environment, thus most older software should run. WIN7 Pro is the best OS MS has had because of the virtual machine ability without having to buy a 3rd party software.
Posted : June 5, 2011 2:49 pm
Guest
thanks Derek & Shelby
I'll send email to Phil, but had thought of the XP option.
Richard
Posted : June 6, 2011 2:56 am
(@peter-kozub)
Sokkia Spectrum Survey
Ver 4.21 L1/L2
Build 1450
Processing Core
Version 3.2
Build 35
Runs fine on vista 64
with L1 only Dongle Lock
PK
Posted : June 6, 2011 7:53 am
