Hi all, Having trouble generating a liscad field file export (2015) with the .job file from my TSC3 controller.?ÿ
First error says "cannot locate the required file converter ()"
Second error says "The selected job file could not be converted to JobXML file.
I've googled suggestions on how to fix this problem but no solutions work thus far.?ÿ
Any help would be greatly appreciated!
I know this has been solied here before.
are you on win10 or win7?
TGO or TB C installed or has been installed previously?
i think it was something messed up with install directories from an elder TGO installation.
you also need the Co??rdinate system manager with gelid models in place.
christof.
Have you tried the JXL Stylesheet Converter??ÿ Typically does a decent job converting data, admittedly I've never created a liscad file with it.
https://www.trimble.com/globalTRLTAB.aspx?nav=Collection-67417
Hi! Have you solved this problem? you can work in the ASCII file generator program?
