Hello all,
after contacting Leica Germany, I found out that the Leica Sprinter 250m is no longer offered. On the market there are still the devices from Topcon/Sokkia in similar price ranges. Can anyone share any experience with this?
Many thanks in advance!
Greetings from Germany
i have an sokkia sdl30. On board software is a bit cumbersome but usable.
I also can hook it up with Magnet Field which works great.
The device itself is a good instrument.
Yeah, they're all fine.?ÿ I've used Trimble, Topcon, Sokkia, and Leica digital levels; they've all worked well.?ÿ Only for very long loops or certain types of documentation do I even use the electronic data collection.?ÿ?ÿ
Do you want to hook it up to a data collector or only use onboard?
The use should be without a data collector, but still the possibility to export the data via transfer cable/USB stick.
What is the device to be used for??ÿ Using a 1" total station and good methodology, one can level surprisingly well.
We have a Sokkia SDL 30 and we??re happy with it. The onboard software is clunky like previously stated
