Aliquot vs. Aliquant
j-penry
(@j-penry)
I want to be sure I am using the term 'aliquot' correctly. I have always assumed that a section broken into four quarter sections would be considered aliquot parts even though each quarter section would not be dimensionally the same or contain equal acreage. If a quarter section is further divided into two parcels by establishing the 1/16 corners at the midway points, the two 80's would typically not contain equal amounts.
Webster defines 'aliquot' as something that contained an exact number of times in something else or to divide into equal parts.
Notice the word "equal". An example being 5 is an aliquot part of 15.
The term 'aliquant', however, is slightly different. Defined as being a part of a number or quantity, but not dividing it without leaving a remainder. An example being 5 is an aliquant part of 16.
Could the word 'aliquant' ever be applied in surveying?
Posted : August 27, 2013 7:53 am
I think you are correct.
I believe the theory behind "aliquot" is when looking at the original government survey of a regular section, all aliquot portions have an aliquot portion of the whole (1/4, 1/16, etc.) and when you are describing a breakdown as the "NW1/4 of the NE1/4 you are describing it "aliquotly". However, when doing a new survey and finding bends at the quarter-corners, and distances that don't equally match their "aliquot" partners, it technically does not break down exactly proportional (except that we hold the original dimensions and proportion to them).
When we move to the breakdown of a "non-regular" section with lots, the "aliquot" descriptions aren't even justifiable by the original governmental survey. Although they are by the definitions in the manual.
Posted : August 27, 2013 8:13 am
stephen-johnson
(@stephen-johnson)
Not according to the latest edition of "Definitions of Surveying and Associated Terms".
They don't have the word Aliquant in their definitions and neither does the dictionary this site uses.
found this in Miriams:
Definition of ALIQUANT
: being a part of a number or quantity but not dividing it without leaving a remainder —opposed to aliquot
B-)
Posted : August 27, 2013 1:49 pm
Would lots be aliquant parts of a section? Would the SE 1/4 of section 6 be an aliquot portion to the whole section 6? To divide up a section "aliquotly", wouldn't you have to set the 1/4 corners 1/2-way between section corners? In the Northern and Western tiers of a Township, they usually go 1/2 mile from the East, and from the south and leave the excess in the north and the West.
Posted : August 27, 2013 1:56 pm
