Adding a little color to surveys
21 Users
Check out the color on this plat!
Also, look at the Basis of Bearings. For this survey, I set the GPS base on a porch, upstairs! Bungied stuff down, and put the base receiver on a prism pole, with the tip in a screw head.
Posted : November 28, 2013 8:25 am
"...to the best of my knowledge and ability, so help me Almighty God."
Never quite seen a cert with so much passion there, Nate.
Posted : November 28, 2013 4:22 pm
(@toivo1037)
There are standards for color?
Posted : November 29, 2013 7:14 am
It's just that way!
Posted : November 29, 2013 7:19 am
I've found mechanical pencils, chisels and screw drivers for corners but never a file;-)
Posted : November 29, 2013 7:35 am
(@norm-larson)
It wasn't the APWA now that you ask. Is was the colors that the utilities were painted on the ground got standardized and that is what changed. Specifically we were using green for storm and red for sanitary sewer and we had to switch those. Water stayed blue of course. There were some minor tweaks too, but, it has been too long
Posted : November 29, 2013 8:53 am
(@toivo1037)
OK that makes sense. We generally do the same here, except a dirty yellowish brownish orange for GAS, but what ya gonna do.
Posted : November 29, 2013 10:13 am
(@norm-larson)
Yes gas has always been an issue. I am doing the same dirty yellow brown and it stills sucks. I am in the process of re-vamping all of our macro's so it will probably be changed
Posted : November 29, 2013 11:30 am
(@stephen-a-calder)
> I use color on maps that aren't going to be recorded. Clients seem to really like them. Here is an example.
That's a pretty good survey, David. If you don't mind an unsolicited opinion, I would reverse the color fill for asphalt and conc. Make it look like real life, asphalt is darker and conc is lighter.
Stephen
Posted : November 29, 2013 6:56 pm
(@davidalee)
:good: Good eye. Thanks.
Posted : November 30, 2013 7:39 am
