HOW TO DO YOU HAVE THE SOFTWARE SELECT THE TEMPLATE THAT YOU WANT WHEN YOU USE START UP WIZARD
Save the template to the same name and location the wizard uses.
I'm old, but I can still hear reasonably well. 😉
I can hear reasonably well I think, but I still had a hard time understanding that question...:-P Maybe it was the ringing in my ear.
Yep that is the question how do I get the wizard to use "my template"
Did you understand my solution?
type NEW
it then prompts you on which template to use
IF we are talking Carlson software, it is ALWAYS a good idea to start all new drawings by using the New listing on the pull down under the FILE tab. I work with 3 or 4 different template setups, so it has become second nature for me to do it this way.
