Trouble drawing arcs all of a sudden
zapper
(@zapper)
I'm having a problem drawing arcs in ACAD Map 2014. I want to draw arcs using start, end and radius, which I've always done before with no problem. I pick the two endpoints and then numerically input the radius distance. Sometimes the command works fine and other times it gives me "invalid" upon entering the radius distance. This is driving me nuts. I've tried all types of scenarios to get the command to work consistently. It may be operator error because like I said, sometimes it works just fine and other times, not so much.
Any ideas what might be going on here? Thanks.
Posted : November 8, 2016 12:10 pm
Dan Patterson
(@dan-patterson)
Do you have to input 'E' for end? Is it suggesting anything in the command prompt?
Posted : November 8, 2016 12:23 pm
With only the endpoints and a radius value how does the program determined which of 2 (probably) radius points you want?
John
 John
(@john)
When I get the "invalid" message, it typically refers to the radius being too large or too small (doesn't fit between the ends).
Posted : November 8, 2016 12:27 pm
stephen-ward
(@stephen-ward)
paden cash, post: 398869, member: 20 wrote: With only the endpoints and a radius value how does the program determined which of 2 (probably) radius points you want?
AutoCAD draws arcs counterclockwise from the first end point to the second endpoint........ask me how many times I've screwed this up. :unamused:
Posted : November 8, 2016 12:31 pm
John
 John
(@john)
Probably half as many times as me......
Posted : November 8, 2016 12:34 pm
sergeant-schultz
(@sergeant-schultz)
Yeah, me too. I want to know how all the mathemagicians out there got all them quadrants and angles bassackwards from our (correct) way of doing things?
Posted : November 8, 2016 12:41 pm
stephen-ward
(@stephen-ward)
Zapper, post: 398866, member: 6470 wrote: I'm having a problem drawing arcs in ACAD Map 2014. I want to draw arcs using start, end and radius, which I've always done before with no problem. I pick the two endpoints and then numerically input the radius distance. Sometimes the command works fine and other times it gives me "invalid" upon entering the radius distance. This is driving me nuts. I've tried all types of scenarios to get the command to work consistently. It may be operator error because like I said, sometimes it works just fine and other times, not so much.
If you enter a radius that is less than half the distance between the end points it will give you the "invalid" response.
Posted : November 8, 2016 12:54 pm
zapper
(@zapper)
John, post: 398871, member: 791 wrote: When I get the "invalid" message, it typically refers to the radius being too large or too small (doesn't fit between the ends).
Stephen Ward, post: 398878, member: 1206 wrote: If you enter a radius that is less than half the distance between the end points it will give you the "invalid" response.
Thanks guys. That appears to have been my problem. Solved. 🙂
Posted : November 8, 2016 1:05 pm
