Hi all.?ÿ Just a quick question here.?ÿ Is the Trimble 5603 compatible with a TSC2 running Access 2015??ÿ ?ÿI bought a 5603 that came with a TSC2 running Controller 2.49.?ÿ ?ÿI also purchased an R8 Model 2 that came with it's own TSC2 running Access 2015.?ÿ I want to run everything from one DC.?ÿ ?ÿIs this possible?
Thanks in advance.
you can run the 5603 and trimble R8-2 with Trimble survey controller 12.49. don't think the 5603 will work with access.?ÿ
Yes, a 5603 will work with a tsc2 running access. You might want to verify that the robotics module was purchased and turned on in access. The only problem may be having to use an external radio on the pole.
James
Great question to ask!?ÿ I've learned the hard way a few times especially with the 3 big manufactures.?ÿ Its called "Planned obsolescence". Jp
Got the R8 up and running VRS on Access 2015.?ÿ Is the 2.4 ghz radio for the 5603 illegal in the states now?
No, the 2.4 ghz radio is still legal.
Thank you.
