TGO - TSC2 File recovery (?)
(@warrenward)
If I delete a file either in TGO or TSC2, is there a way to recover it?
Thanks in advance as always.
ww CO PLS
- Have a nice day! Or, may your monument prevail over some guy's touchscreen.
Posted : March 26, 2014 8:27 am
(@christ-lambrecht)
Hi,
speaking for Trimble Access on the TSC2
TGO: depending on your Windows version and network settings you may find it in your Recycle.bin You know your job and dc file are stored in the Data FilesTrimble Files
subdirectory of your TGO-project.
TSC2: once you deleted your job file from your working directory thers's no way to recover your file on the Windows CE system as far as I know! But you did not delete these files in TGO AND on your dc did you ???
greetz,
Chrstof.
Posted : March 26, 2014 11:10 am
(@clb-surveyor)
> ww CO PLS
You may be able to recover the file from the actual GPS unit. Using the TSC2 with Spectra Survey Pro, under the Survey Tab -> File Management, I believe you can access "recoverable" files. I have found deleted files in there before.
Posted : March 26, 2014 1:48 pm
