We recently purchased TBC and Trimble Total Stations in order to coordinate with a Teaming partner. We definitely like the Total Stations and have processed the data successfully by using RW5 files in SurvNET in Carlson. The main problem we are having in TBC is once the field crew enters coordinates for points in the data collector we have not figured out how to change/correct the coordinates. Is it really hard to edit raw data in TBC or is there an easy work around that we are missing? Our field crew used some bad procedures that were easily fixed in SurvNET. Any insight would be appreciated.
It took me a while also, use the navigator function to edit. The points show up on a tree on the left hand side of the screen, use the + button to access the point you want.
sorry not navigator---the explorer function-access it under View
OK I have gotten to that point. The question is how can you change the coordinates of the point?
If you expand the point itself you should see a coordinate record - the icon looks like a little target, typically it will say something like Grid (xyz.job) next to it where xyz is the name of the job in the collector. Right click on that coordinate record and select Properties and you can edit it's coordinate and class (control, survey, mapping, unknown).
Thanks. That was precisely what I needed.
Ol'Lee to the rescue. Good job sir.
