How do you take your map* out to the field digitally?
I prefer to use mbtiles format and load it to mobile app to viewing with smartphone/tablet. To convert geospatial data (commonly in shapefile) into mbtiles, Tilemill is quite good. It provides advanced styling called CartoCSS to enhance map's cartographic
Sent from my XT1585 using Tapatalk
DWG FastView android app
Really hard to see anything on phone out in the sun.
Use for backup when I need to see where points are when in the field and things don't look right.
Typically it is loaded as a base map right in my data collector survey file
I mean how to create base map to use with your preference app.
How do you combine your datasets into single basemap and use it as base map?
Usually DXF other options are geotif, jpeg, open street map, and shape files. As long as the same coordinate system is used I don??t really see an advantage to combine data sets in cad. Smaller files that you can reference and un refrence make the software work smoother than 1 big file
I prefer the analog method - paper. I can make notes on paper maps, which you can probably do with your digital copies. I can easily scale distances and directions on paper, which you can probably do with digital maps. I can read paper maps in direct sunlight, which you may be able to do with digital maps, depending upon the device you are using.
But...
I can drop a paper map and not worry about it breaking.
Paper maps can be read and used even after the batteries die.
In an emergency out in the woods, I can tear off portions of a paper map that I don't need if I have forgotten to pack a bag of tissues or napkins.
Try that with your I-thingamajig!
To add to Evan's post, I prefer paper maps (drawing with aerial) to a handheld GPS. The mere process of finding myself on the aerial helps with finding boundary evidence. Continually glancing at the ground is far better than staring at a screen while blindly wandering around in circles. 🙂
