Survey Pro 5.5 Deleting Raw Data Records after Transformation
5 Users
bow-tie-surveyor
(@bow-tie-surveyor)
I just started a new management position with a Florida County and they use Spectra Precision Survey Pro for their data collection. I have been having the crews output their .RAW file from the .Survey file, so that I can run them through an adjustment. But I have noticed that if they do a transformation mid-file, Survey Pro will delete the observations of the transformed points in the .RAW file and replace them with the transformed coordinates. I can still see the observations in the collector, so they must still be in the .survey file, but I can't seem to get to them to adjust them. Anybody else had this problem?
Posted : April 5, 2018 7:17 pm
jimmy-cleveland
(@jimmy-cleveland)
Do you have Spectra Precision Survey Office or Trimble Business Center? If so, you may be able to get the information from there. I do NOT like the fact that you cannot export a *.job and *.raw file from SPSO or TBC. Many adjustment programs (I use Carlson), need the *.raw file.
Posted : April 5, 2018 8:05 pm
bow-tie-surveyor
(@bow-tie-surveyor)
Posted by: Jimmy Cleveland
I'm running a demo of Spectra Precision Survey Office to see if it is worth buying. I do not see an option to export .survey file to .raw.
Posted : April 6, 2018 1:17 am
dcn
 dcn
(@david-c-newell-rpls-ls-cfm)
http://trl.trimble.com/dscgi/ds.py/Get/File-394365/TDS%20RW5%20file.zip
This is a style sheet that will output a RW5 file
Posted : April 6, 2018 10:22 am
This is an issue with Access as well.
never ever never never translate your survey to control coordinates. Translate your control coordinates to your survey...OR...export a csv file, combine it with your control coordinates in a new job then translate.
I made this mistake once. Somehow I got the deleted raw data back, in TBC I think but don't remember. It seems to me I somehow cut and pasted it into a text file from the optical spreadsheet then manually edited it into a StarNet DAT file, a painful process.
Posted : April 6, 2018 1:43 pm
I realize that sometimes one must alter one's preferred workflow to accommodate the peculiarities of one's software, but the above is a perversion of common sense.?ÿ Reading it makes me glad that I'm a SurvCE user.
Posted : April 6, 2018 2:12 pm
