Is anyone using this successfully and could maybe help me out what I am doing wrong?
For some reason most of my observations are coming through as DV records (no horizontal angle).
They are all F1/F2/mta (mean turned angle) observations.
If I export using "all observations" I get some DM records. If I export using "averaged observations" I get no DM records.
I am trialling the latest version 8.1 of the program.
Cannot attach the relevant here but they can be downloaded from here-
JXL File - http://tinyurl.com/ogfw6ho
DAT File - http://tinyurl.com/ptarynj
Thanks in advance for any help. I know there are a few keen starnet users and this is what has interested me in trying it. Not sure who is using the converters though.
I don't have an answer, but I have a question. Do you have the option of exporting the data in some other format that Star*Net will also convert? SDR? RAW?
I think that you can still download v7. You might try it and see if the converter in that version gives you the same problem. I recently discovered a problem with a file converter in v8 that had worked fine in v7.
I can attest that the file converter for Trimble Survey Controller worked just fine in v6. Unfortunately I no longer have access to it. I do not think that any of the settings in the converter are what is giving you your present troubles.
Everybody who uses StarNet should be using a data converter. Without that the experience would be an unhappy one.
Trimble has a little utility called "Ascii File Generator" which can be used to convert .job and .jxl files to other formats. Among the available style sheets is a Starnet converter. I have run your file through it and have what appears to be valid data.
## This file has been exported from Trimble Survey Controller!
## Job File: 150108
## Created: 2015-01-08
## Instrument: S6 2 DR Plus
## Serial Number: 93010230
C 2 -13.587 -1.750 20.718 * * *
C 1 100.000 -1.750 20.000 * * *
.DELTA OFF
A 2-1-318 355-53-11
A 2-1-420 353-45-41
A 2-1-320 355-24-12
A 2-1-220 357-24-58
A 2-1-120 359-01-31
A 2-1-421 353-21-25
A 2-1-321 355-06-21
A 2-1-221 357-14-31
A 2-1-121 358-56-43
A 2-1-422 352-56-51
A 2-1-322 354-47-31
A 2-1-222 357-02-34
A 2-1-122 358-51-01
A 2-1-423 352-27-53
A 2-1-323 354-25-58
A 2-1-223 356-48-42
A 2-1-123 358-44-14
A 2-1-424 351-50-13
A 2-1-324 353-57-45
A 2-1-124 358-36-29
A 2-1-224 356-31-51
A 2-1-425 351-13-26
A 2-1-325 353-28-52
A 2-1-225 356-14-25
DV 2-1 1.646/1.643
DV 2-318 59.920 91-37-09 1.646/0.000
DV 2-420 54.191 91-48-02 1.646/0.000
DV 2-320 53.950 91-44-51 1.646/0.000
DV 2-220 53.781 91-47-10 1.646/0.000
DV 2-120 53.733 91-43-15 1.646/0.000
DV 2-421 51.068 91-52-06 1.646/0.000
DV 2-321 50.884 91-49-11 1.646/0.000
DV 2-221 50.784 91-51-32 1.646/0.000
DV 2-121 50.749 91-47-37 1.646/0.000
DV 2-422 48.289 91-56-59 1.646/0.000
....and so on for many pages. It makes me think that the problem is with the StarNet converter and not with your data.
Thanks very much, both of you, for your help.
I have already (successfully) used the StarTSC converter to convert from Trimble DC format.
Also the Trimble stylesheet used above (I used it on the logger directly).
I am not 100% happy with the output though as it uses DV and M records (StarTSC) and DV and A records (Trimble stylesheet).
The problem with these records (for me) is - for example - I had a situation the other day where I had to take my monitoring readings first, and backsight last. I was waiting for fog to lift, it saved standing for 1 hour as the monitoring stations were much closer to the instrument I could see them. I would normally take backsight before AND after but in this situation I was prepared to take the risk and check the data thoroughly and redo if necessary if the orientation drifted.
As the M and A readings describe horizontal angle from the backsight, the backsight cannot be changed. (without recalcing all the angles). The DM records would be ideal for my purpose.
I forgot to link to a DAT file converted from a different JXL where it put a few DM records in but I can't work out what was different about these points!
JXL file - http://tinyurl.com/mtph45w
DAT file - http://tinyurl.com/mcamrpg
Also both of the above methods averages my f1/f2 readings before they get into the DAT file. I want to see these ideally, for example to remove an unbalanced reading (2 f1 and 1 f2). I don't like going into the DC file to delete these, which is what I've had to do.
These methods also average multiple sets eg merging backsight readings and backsight checks at end. Even though I have unticked the box (in StarTSC) to do this.
Basically I want something where I can see every reading and chop and change, the raw data. I like the text based format DAT file for this. The LSA facility is also great when I need it. As you can see in the files on that day there is no redundancy (or any need for it).
So it seems no-one is using the StarJXL converter? I will have to enquire with Microsurvey. I am not sure what their support is like for trial customers?
Thanks again, Roger
Understatement.
:good:
