I am running AutoCAD Civil 3D 2015 with Carlson Survey 2015 add-on package.
In my "Import Text/Ascii File" dialog box, I have the coordinate order set for point, northing, easting, elevation,description and several note fields.
A typical point in my CSV file looks like:
40025,97988.013,2016618.196,1331.307,mon,undisturbed,2-Jan,found,iron rod
In the past, when I would import a CSV point file and use the draw-locate function, it would place a point block with the point number, description, elevation and then it would add the notes on individual lines of text on a note layer underneath the point block. For some reason it doesn't seem to be labelling the notes anymore. Is there a variable somewhere that got turned off that I'm missing? I know it used to work.
Based on what you've posted:
P=40025
Y=97988.013
X=2016618.196
Z=1331.307
D=mon
N=undisturbed
N=2-Jan
N=found
N=iron rod
In the title of your thread, you have "...D,N,N,N,N,N" (5 N's as opposed to 4) which might be causing the problem. I hope this information helps.
Actually, my format is?ÿP,Y,X,Z,D,N,N,N,N,N,N,N,N,N,N
We collect a lot of metadata which goes into a very robust GIS for our client. I don't think the presence or absence of data in the additional fields has ever been a problem.
not sure if you already fixed it but I believe your solution would be to create a new label style and add each of the fields to the label. Have you tried that?
Do you have "notes" checked in the Draw Locate Points Dialog??ÿ
Winner, winner! Chicken dinner!
That's the button I was looking for. I was just looking in the wrong dialog boxes.
Thank you!
I am a fan of SurvNet and output the NEZ with standard errors.?ÿ The trick there is to input PYXZSSSSD where the S is to skip.?ÿ Won't bring in the data but that is not my intention.
