Gurus and such,
I am using AutoCAD 2014- vanilla (not civil 3D)
When I want to copy or move something, I select it and then head toward where I want it to end up. If I get close to some other object, such as the end of a line, or something, I get green orthogonal lines emanating from the end of the line, and a small dialog box, like this:
Endpoint: <E, Endpoint: <N
I assume I have some toggle on that I don't want or I have one of the selection options incorrect.
I don't want to see this critter.
How do I get rid of it?
Many thanx,
Geezer
F# key or the command "OS" and hit the clear all button.
I think it's called "flyover, object snapping". At least that is what IntelliCAD refers to it as. It never seems to "snap" to what I want either.
Another pain in the butt is "orthagonal snap". It throws a line in one of 4 directions (up, down, left and right). Have you had that one?
You have some onsnap features that are turned on.
Settings
Object Snap
snap menu selection box should open and check them on or off as you desire
OK
I think maybe that on the fly you can shift-rightclick and bring up the o-snaps and tell them which one you want, including none.
Cheers,
Henry
