Magnet field - manipulating a dwg or dxf
(@arctanx-2-2)
Is it possible to translate or rotate an imported drawing to aid in staking out deed corners?
Posted : 08/02/2017 10:14 pm
(@beuckie)
I have no access at the moment but i believe somewhere in the Cogo menu. This is with version 4 though. It's certainly possible.
Posted : 08/02/2017 10:55 pm
(@arctanx-2-2)
Bump. Lee?
Posted : 09/02/2017 6:30 pm
(@leegreen)
Yes, there are a few ways to do this.
Unfortunatly I am heading to Orlando airport now for 1pm flight back to frozen, snow covered NY.
Posted : 10/02/2017 8:02 am
(@leegreen)
arctan(x), post: 413198, member: 6795 wrote: Is it possible to translate or rotate an imported drawing to aid in staking out deed corners?
Yes and no. You can't translate the drawing separately. But you can transform the entire project using 2d Transform, which works similar to a localization. You can translate and rotate points to bring your points to the drawing datum.
When importing CAD files I suggest you always "Load as background drawing", it is under settings during the import. This will load the line work much faster. It can include the text and blocks as points. You will also have the option to turn on/off the linework, and delete the linework file. Each file will serve as an Xref or sorts in the map properties
menu.
Posted : 11/02/2017 11:45 am
(@arctanx-2-2)
Thanks, Lee. I'm disappointed I can't move the drawing to my points. My typical work flow in Survce is to import a dxf of the subdivision or deed and then once I find some corners I will move and rotate the drawing to aid in the stake out process.
Who do I talk to about getting that put on the to do list?
Posted : 11/02/2017 9:29 pm
(@leegreen)
You can talk to [USER=8922]@pmoran[/USER] from Topcon/Sokkia about this.
Posted : 11/02/2017 10:55 pm
(@pmoran)
I'll check with Product Management.
Posted : 15/02/2017 5:25 am
