Hi,
I have a GIS grade Leica GG04 smart antenna.?ÿ It is a dual frequency receiver/antenna that can produce a *.m00 file and I have been successful in submitting and producing an OPUS solution using OPUS.?ÿ I do not have any Leica software and looking for something along the lines that Trimble provides -?ÿ https://gnss-processor.trimbleaccess.com/gnssprocessor
any ideas?
I've heard that OPUS can read m00 files directly.?ÿ Have you tried it?
Hi Joel,
OPUS should take m00 files in native format - I have submitted them as recently as a month ago and gotten back solutions. Haven't used that specific antenna, but the NGS likely has a calibration for it.
Trimble RTX post-processing (one of the options on the survey tools menu) will provide NAD83 values, but I don't know if they support that exact Leica antenna. It does support some Leica models though. Might be worth a try...
Thanks Rover83,
I'll have to check out RTX - that is a good idea. The GG04 spits out a *.m00 file that does return a file that successfully makes it thru OPUS.?ÿ There is an ANTCAL for it too.?ÿ ?ÿ
The GG04 file has dashes "-" in file name which forces a rename on the file by hand before its accepted. Small detail, but hey, I work with Ologists!.?ÿ Strange that OPUS kicks back files with "-" instead of "_".?ÿ?ÿ
Thanks
