IT"S HERE!!!!!!
8 Users
(@cptdent)
The update for Carlson Survey Embedded is available at http://update.carlsonsw.com/updates.php?&product=CarlsonSurveyEmbedded&version=2015
The following files have been updated:
FileName:CarlsonSurvey2015_Embedded.exe
Description: This is a full version of Carlson Survey 2015 with Embedded AutoCAD 2013. The serial number is required for installation.
Posted : 13/08/2014 6:11 pm
(@scotland)
Enjoy. I've been trying out the new IntelliCAD 8 with Carlson 15. Had one issue that seems that the culprit had been found. Now to see if it gets fixed soon. Other than that, the program works well. I miss the ribbons from ACAD and express tools. But other than that I haven't struggled too much.
Posted : 13/08/2014 6:42 pm
(@james-johnston)
Nothing too special in this new version as far as I can tell, a few new bells and whistles.
Still trying yo figure out how to export 3D PDF. Where is the routine, not too sure. The software is also capable of creating movies of the 3D drive by. It seems that movies can only be viewed within the program. Which is less of an appeal if you want to make movies to send to clients.
I haven't played too much with it yet, so it maybe a case of user not knowing.
Posted : 14/08/2014 4:46 am
(@ctompkins)
PDF File Size
Not to hijack the post, but I have been using Intellicad v7.2 with Carlson 2014, (I got lucky and bought it just before the new release....yea for me!!), anyway, Just out of curiosity, what kind of pdf driver are you using to print with? Currently I am using "PDFCREATOR" but the file size is anywhere between 50-70 MB!! The same exact drawing using Autocad's "DWGtoPDF" driver the file size is around 2 mb. Any ideas?
Posted : 14/08/2014 5:34 am
(@jerrys)
PDF File Size
Not to hijack your hijack, but if you bought the OEM version in the last 90 days, you may be entitled to the just released 2015 at no additional cost. Certainly worth checking on...
Posted : 14/08/2014 6:08 am
(@norm-larson)
PDF File Size
Guessing here, but, it sounds like it is converting to raster and dropping the vector information. Has to be a setting there somewhere
Posted : 14/08/2014 6:40 am
(@ctompkins)
PDF File Size
Thanks...I will check into both.
Posted : 14/08/2014 7:04 am
(@lowcountrysurveyor)
PDF File Size
I've been using cutepdf for about 10 years now.
Posted : 14/08/2014 9:05 am
(@ctompkins)
PDF File Size
I have looked at cutepdf and have a few questions.
1. what size are your files typically?
2. do you have the free version or did you pay for the 'professional' version?
Posted : 14/08/2014 9:58 am
(@j-t-strickland)
PDF File Size
Check your density, seems like the default is max, which makes huge files.
now, back to your regularly scheduled broadcast:
Posted : 14/08/2014 1:03 pm
