Is Autodesk Civil 3D a chimera?
10 Users
bow-tie-surveyor
(@bow-tie-surveyor)
I am a County Surveyor that works within a county public works department with various engineers and engineer techs. Over the past year and a half I have been working on providing Civil3D deliverables it what I believe to be the way that I think Autodesk intends. All the points have symbology defined by my survey template (that I ripped off from the Florida Department of Transportation), most all of my survey location linework consists of full 3D Civil 3D Survey Figures defined by my points as inserted into the Civil3D Survey Database. My surfaces are created from the Civil 3D points in the drawing and the Civil 3D Survey Figures contained within the Civil 3D Survey Database. I'm sure I could do some things better, but I think I'm providing a proper deliverable.
So anyway, I have been asking the engineering techs who work with my drawings if they are able to use all of these smart dynamic 3D entities that I am creating to their advantage. The answer that I'm getting back often time is no. They use the surface alright, but having a surface entity for surfaces really isn't all that new to Civil 3D. We had them in Land Desktop and Carlson. The don't seem to really interact with my points all that much and actually they complain about the symbols dynamically scaling up and down when they change the scale on their drawings. They would rather them stay just they way they show on the survey. I had a similar issue when I would use annotative text in my drawings. They didn't like my text scaling up and down when they would change scales. So I had to stop using it. It does not appear that they interact with the 3D Survey Figures at all. And sometimes they complain about them because they are difficult for them to use at all. They end up having to trace either?ÿ 2D or 3D polylines over them to work with them.
When I look at things on my end, I find Civil 3D difficult to work with. It seems to make things a lot more complicated than they need to be. Early on, I discovered that it has virtually no useful survey data processing capability. I like most people use a 3rd party survey data processor (Star*Net in my case) to go from raw survey observations to coordinates that I import into the Survey Database. I find the Survey Database constraining in that I have difficulty making post-import edits to the points and it not having the COGO functionality that I am used to having with other software. I have had issues with the survey database being in one coordinate system and the drawing being in another slightly different coordinate system and Civil 3D "helping" me by doing a coordinate transformation without any warnings that it is doing so (been burned by that more than a few times). I would set all of my settings to no datum and unitless if I could, but it wont let you do that. I find it odd that feature styles for my points are defined by my drawing template, but the styles for the Survey Figures are defined by a separate file on my local hard drive (kind to hard to keep everybody in the office on the same page when an edit to the feature table needs to be made). I find Survey Figures hard to work with in general. If they weren't used for the automatic linework function and needed for the surface, I don't think I would use them at all. Also, the overall performance of the program seems poor. It seems like I am constantly waiting on it to complete one function before going to the next. I that can be something as simple as editing a piece of text.
So, what is the takeaway? Why should my survey department go though the pain of using a program that is difficult to use and does not appear to give much benefit to the engineers down the line? Has anyone out there seen the promised Civil 3D utopia where everything just works in either a survey or engineering department? Seems like everybody just keeps trying to work toward the perfect template that will do everything they want it to do. Is it a chimera? Has anybody got there yet? Right now, I am seriously considering transitioning over to something like Carlson Survey and just deliver an AutoCAD deliverable with LandXML file. Thoughts?
Posted : July 16, 2019 8:58 am
LcBookout
(@lcbookout)
Sounds like both you and your clients need Survey Technicians and Cad operators. Where I work, we have been building workflows that utilizes a great deal of C3D objects and techniques for surveying and civil engineering, even accommodating outside offices that only use vanilla AutoCad. As immense and complex as C3D is, no one is ever going to be using 100% of its capabilities, yet in competent hands, it can configured to perform for almost anyone's discipline. That's why dedicated Cad operators and draftsmen are a thing.
Barring that... Carlson is a good program, so is Bricscad, if you want to stay with the dwg format and keep it simple without all the bells and whistles.
Posted : July 16, 2019 10:41 am
dgm-pls
(@dgm-pls)
Yes it is a chimera.?ÿ I know people that use it a lot, love it.?ÿ People that don't struggle with it.?ÿ I like some parts of it but find other software is a lot more efficient at completing the project.?ÿ Land XML seems to handle getting the surface into other people's software well.
Posted : July 16, 2019 11:50 am
blitzkriegbob
(@blitzkriegbob)
Didn't we have this discussion not that long ago (like 13 pages worth) on another thread you started??ÿ It sounds like you are creating a product that I would like to use.?ÿ It also sounds like the techs you talked to could use some training.?ÿ Here are a few points:
  1. I like my symbols to size up or down with the scale the same as you. However, if you want to satisfy them, you can set your point symbols to use a fixed scale.
  2. I don't really interact much with the points or survey figures either, but isn't that what surveyors, especially on this site, would prefer??ÿ Actually I really can't do anything with figures unless I have the survey database, which I never get.?ÿ I can't imagine what I would do with the figures.?ÿ That is your survey.?ÿ I'm not going to change it.?ÿ I may create point groups from your points, or I may make a modification to some point styles on occasion.?ÿ Almost every C3D survey I get has the Point Style Marker with an orientation reference set to WCS and I prefer View.?ÿ Even though I'm not nuzzling up with the points and figures doesn't mean I don't appreciate them, because I do.
  3. I think I mentioned this in the last thread also, but I would ditch the annotative text and instead use a Note label wherever possible.?ÿ Not because of scaling up or down, but because I can set that orientation reference to View also.
  4. I missed this in (2), but I don't draw over the top of survey figures any more than I would draw over the top of a polyline that Carlson would draw.?ÿ Why do they need to do that?
  5. Yes, adjustments and databases and survey figures can suck.?ÿ Actually editing survey figures was so difficult that it inspired me to push the field crews to new and better ways of connecting line work.?ÿ Once they got the hang of what I was asking them to do, I rarely had to touch the figures.
  6. There's no utopia. There's no perfect template.?ÿ There's no perfect style.?ÿ I don't know that I want it to exist.?ÿ I can't imagine a day where I'm not looking for a new and better way to do a task.?ÿ One of the reasons I don't work for big companies is because I don't want to sit down and follow a manual that gives me step by step instructions on how to complete a task.?ÿ My bosses have been pushing me for a couple of years to make such a manual and I've successfully dodged that bullet so far.?ÿ Utopia doesn't exist with Carlson either.?ÿ I used that for about a year, and I would take C3D over that any day of the week.
That's my 0.38 pesos.
Posted : July 16, 2019 12:08 pm
blitzkriegbob
(@blitzkriegbob)
Posted by: @dgm-pls
The more I work with XML files, the less I'm impressed with their results.?ÿ We work a lot with companies that use Microstation, so almost all of our projects involve the sharing of XML files.?ÿ Here's the latest example I have of discrepancies between platforms.?ÿ This is two views of the same profile.?ÿ The white dashed line is the existing grade produced by a Microstation firm using their survey and their surface.?ÿ They provided an XML file of the surface to us.?ÿ I used that XML file to create a C3D surface.?ÿ I made no modifications to their surface.?ÿ I made an existing grade profile, which is shown in red.?ÿ Obviously the two do not match up.?ÿ In some places there is several feet of difference.?ÿ Granted, this profile is about 5900 feet long, and there are long stretches where the two profiles match up perfectly, but these two areas are not the only places where they deviate.
Posted : July 16, 2019 12:27 pm
bow-tie-surveyor
(@bow-tie-surveyor)
Posted by: @blitzkriegbob
Yes, I'm aware that I can do that, but then I loose control of the size of my symbology on my surveys which can range from 1"=10' (on details) to 1"=400' (on section breakdown sheets). Is there any way to do that globally without having to modify each individual point style.
When I say interact, I mean they are of some use to the engineers other than to just look at. Do these special 3D line entities help them in any way? Oh and thank you for pointing out the orientation setting on the points. I think I will change mine to View as well.
OK, I've seen Note labels, but never used them.
OK, I have seen it a couple of different times. On one occasion, they wanted to place a guardrail a certain number of feet away from the existing edge of pavement. As the edge of pavement in my survey was a survey figure, he could not just offset it apparently. So, he just traced a 2d polyline over it and offset that to accomplish what he was trying to do. On a second occasion (with a different engineering tech), he was designing a sidewalk which he wanted to design relative to the existing edge of pavement. So he wanted to target my edge of pavement for his assembly of his typical section. He said that it is possible to target a survey figure. However, when it is xrefed, he is unable to access it. There also appears to be no data shortcuts to use survey figures either. He showed me that he was able to extract feature line from objects within an xref, but he was unable to select survey figures. So, he ended up just tracing a feature line over the xrefed survey figure and used that.
Yes, same here. We don't have to edit very much, but when we do, its not easy.
Posted : July 16, 2019 1:19 pm
blitzkriegbob
(@blitzkriegbob)
Posted by: @bow-tie-surveyor
I'll just tackle this right now since I'm running short on time.?ÿ I haven't had to do this, as I've never received the same request, so this is theoretical.?ÿ I would normally have numerous point groups in my template that would become populated as points were being imported.?ÿ I can envision having two sets of point groups for, as an example, a utility pole.?ÿ One point group is for your use, one for the engineers to be able to see.?ÿ Yours would have the scaled point symbol, theirs would be fixed.?ÿ I imagine you are familiar with being able to order your point groups??ÿ What I would do, at the point that I was going to package the drawing to the engineers, would be to have the engineering point groups ordered above a No Display point group, with your point groups below the No Display.?ÿ So they will see their fixed scale symbols and not your scaled symbols.?ÿ Rearrange the ordering after that, and you're back to where you need to be.
Obviously much set up time, but once that's done you should be set.?ÿ Give it a try with just a few symbols and see how that works.
Posted : July 16, 2019 1:53 pm
jaccen
(@jaccen)
Does setting annotative text to "Match orientation to layout -> yes" not accomplish what you want?
I use that for text/mtext I want to match the layout.?ÿ I use torient for other text I want to align to a, well, line.?ÿ Middle centre insertion point and it's good for just about any scale.
Posted : July 16, 2019 3:17 pm
dgm-pls
(@dgm-pls)
@blitzkriegbob
Was the XML the version with the error?  If so, any ideas on what could be the cause?  We send them out all the time and I do run some QC checks on the files by bringing them back into a project to see what the results look like.  I usually do that out from carlson and then bring it back into Carlson but I might switch that up a little and bring into Civ3D.
Posted : July 16, 2019 5:27 pm
cameron-watson-pls
(@cameron-watson-pls)
Survey Figures SUCK!?ÿ Flat out, they're basically a feature line but they're not.?ÿ I have no idea why Autodesk can't find a way to scrap them in favor of only having feature lines but it doesn't seem like they can.?ÿ I import my point files through the Survey DB, auto-draw my linework, make necessary edits to codes then when I'm happy with it I insert the points from the DB into the drawing and convert all figures to feature lines, close the DB and likely never touch it again, unless we have to go out and collect additional topo.?ÿ Our Engineers use both our points and the feature lines quite extensively through the course of their design.?ÿ I don't usually know going in where new curb cuts will need to be located so it's useful for them to be able to hook proposed curb returns into existing curb lines between the as-built topo points without having to interpolate match grades as an example.?ÿ Your mileage may certainly vary and like I said in the previous post on the topic, if the end user of your data doesn't see or get value from your C3D deliverable, use the software platform that makes the most sense for you and keeps them grinning.?ÿ To be completely honest though it doesn't sound like your Engineering counterparts are leveraging the capabilities of C3D, tracing over lines you've already created is a ridiculous waste of time.?ÿ ?ÿ
Posted : July 16, 2019 7:11 pm
What's the difference between a feature line and a 3D polyline?
Posted : July 16, 2019 11:33 pm
Randy Rain
(@randy-rain)
@jim-frame
In a nutshell, mapping wise, it's line-type. Feature lines are 3-D and they display line-type properly, that and they also have a powerful set of tools for creating and editing grading. I use them for most of my grading. It's very handy to be able to move the cursor along the object and edit either the existing h/v/slope values or create new ones on the fly.
Posted : July 17, 2019 4:17 am
clearcut
(@clearcut)
Feature lines can contain attributes, field notes and links to photos. All handy for bringing field survey data into a drawing. Feature lines can be true curves. Feature lines auto project onto cross sections with auto labeling of the feature linesƒ?? individual name, such as EP-1 or HP-4.
When exploded, all of these functionalities are lost and you are only left with 3d polyline segments.
Posted : July 17, 2019 5:10 am
A 3d polyline can't have curves in it. Feature lines and Survey Figures can.
Posted : July 17, 2019 6:21 am
bow-tie-surveyor
(@bow-tie-surveyor)
Posted by: @randy-rain
So... Survey Figures do have a use for design. Can you use them this way if they are embedded in an xref or do they have to be the drawing you are working on?
Posted : July 17, 2019 6:50 am
jaccen
(@jaccen)
@jim-frame
You can also use featurelines to create a corridor model in C3D (use the featureline w/ an assembly).  Useful if you want to create a corridor but don't want to go to the bother of creating an alignment and a corresponding profile.
I use featurelines w/ corridors to grade swales, model retaining walls, do cut/fill analysis of excavations..........heck, I use them to grade sidewalks as I only have to grade one featureline instead of two.
They are a very useful design tool.
We use survey figures to make the survey DTM, but that's it.  The engineers want the linework w/ a z=0 so we save a copy, flatten it (while maintaining all the arcs, etc.) and give them an export of just straight dumb CAD for their base drawing.  Data shortcut in the surface and everyone's off to the races.  They don't touch the surface in the survey database.
Side note--I find that featurelines "lose" their curve/arc capabilities w/ very large files.  Possible solutions are:
-use arc2segment on a polyline to recreate it w/out arcs
-use a very small mid-ordinate distance
-use a very small corridor instead (ie. a line 0.01m wide)
Posted : July 17, 2019 7:01 am
blitzkriegbob
(@blitzkriegbob)
@dgm-pls
I don't know that I would call either of the profiles an error.  I think it's just a case of different software interpreting a DTM differently.  Obviously I think the profile I created, in red, looks more pleasing than the spikes shown on the Microstation profile.  But's it's their data and their surface, so I'm not sure I can say that there's is wrong.  I bet if they imported their XML file in to Geopak that it would be a perfect result.  I usually check my XML files also, but how do we really know that another platform will get the exact same results.
This isn't the first time I've seen a discrepancy.  We do a lot of work with this firm, and this job is a little different in that they took the plans to the first submittal before passing them off to us and another subconsultant to take them to final. They gave us XML files and converted DGN files.  I recreated their profile, noticed that it was different than what their profile showed, then pasted their profile line in to my profile for verification.
What if the profile was cut 20 feet to one side or the other?  Would everything be fine?  I don't know.  I just think there's no way to be sure that a surface created in one platform will be EXACTLY the same when recreated with an XML file in another platform.  I think there's just a blind acceptance that sharing XML files is an answer to all our problems.  I only have C3D, but I'd love to hear the results if you tried doing the cross platform thing.
Posted : July 17, 2019 11:09 am
blitzkriegbob
(@blitzkriegbob)
@jaccen
I rarely use annotative text any more, but yes, I believe that you are correct.  My counterpoint would be that using a label gives you a ton more flexibility.  For example, what if you needed a leader with your text?  You can't match the layout orientation with a multileader.  Yes there are multiple ways to have them align with other objects, but all that includes more steps to get to the same place as using a note label.
Do you type up the same text callouts for each project?  I can have a label that I use over and over for every project.  You can set up different multileader styles that have predefined text, but you lose your orientation again unless you spend the time to make them match an orientation.
Correct me if I'm wrong, but you still have to assign different scales to your annotative text.  Do you do that in anticipation of the needs of someone else?  Leave it up to them?  I know it's not a big deal to do that, but it's not anything you have to do with a label.
Also, if you set up parent/child relationships, if someone comes to you and says they want all the survey labels to have a text height of 0.06 instead of 0.08, or to use a different arrowhead, you would only have to modify the parent label and all the child labels will take on the new properties.
The one thing that is missing from a note label that I would like to see would be the inclusion of multiple leaders.  Right now we are limited to one leader.
Again, I just like the flexibility that a label provides, and IMO, it makes for less work.
Posted : July 17, 2019 11:25 am
jaccen
(@jaccen)
@blitzkriegbob
All very valid points.  I think I'll try out notes for a few of my designs going forward.  Thanks!
Side note: a hack, but this seems to be a multiple leader solution for notes:
https://forums.autodesk.com/t5/civil-3d-forum/note-labels-multiple-leader-arrows/td-p/6539429
Posted : July 17, 2019 12:22 pm
jaccen
(@jaccen)
@blitzkriegbob
Do you place fields in your notes?  I use them quite a bit for their equation ability.
Posted : August 6, 2019 12:47 pm
