Intellicad 10 - Arc command
(@stephen-ward)
I've run across an issue in Carlson 2021 (Intellicad 10) where arcs are drawn incorrectly.?ÿ I often run in plats or deeds using chord bearings, then go back and draw in the arcs using the arc command (start, end, radius method).?ÿ If dynamic input is enabled (where you key in input at the cursor rather than on the command line) the arc command will take the radius dynamically from your cursor position rather than using the number you key in.?ÿ Setting DYNMODE to (0) will cause it accept your radius keyed in at the command line rather than grabbing a random radius based on your cursor position. I've submitted the issue to Carlson.
Posted : January 8, 2021 12:29 pm
 jph
(@jph)
Another reason to hate dynmode, and keep it at 0
Posted : January 8, 2021 12:43 pm
(@va-ls-2867)
I never use dynamic input.?ÿ Too much added fluff.?ÿ I am set on my ways from Autocad 10.
?ÿ?ÿ
Posted : January 9, 2021 3:14 pm
(@stephen-ward)
I'm pretty sure it's turned on by default on fresh installs, or maybe it came over when I imported my previous settings. Just a heads up for anyone who upgrades.
Posted : January 9, 2021 3:39 pm
