In Carlson 2012 iCAD....?
Pin Cushion
(@pin-cushion)
Thanks for your help guys, yall alway come through.
I want to push in a deed and have only lines.... No points. Is there a line by direction command? Or do I have to use traverse and get the points that I don't want???
Posted : March 4, 2012 7:34 am
LowcountrySurveyor
(@lowcountrysurveyor)
I think you want:
COGO / Line By Angle/Distance
After selecting this, press "h" for help. It will show you your bearing choices.
1=NE , 2=SE, etc
Posted : March 4, 2012 8:24 am
Steve D
(@steve-d)
Great - Thanks, I have always used the extend command (with "B" for bearing) or the enter deed description. I did know that this command existed.
Now my question is; how do you continue entering the deed with a tangent or non-tangent curve?
Posted : March 4, 2012 9:25 am
cptdent
(@cptdent)
Enter the Chord Bearing and Distance. Then you can go back and add the curve using the Arc "PC/PT/Radius" option.
I don't used the ICAD version, but there should be selection boxes that can be unchecked in your Traverse setup routine where you can turn off point numbers and labels.
Posted : March 4, 2012 10:03 am
Pin Cushion
(@pin-cushion)
you the man... THANKS!!!!
Posted : March 4, 2012 10:51 am
Brent Webster
(@brent-webster)
It's much easier if you go to the survey tab an select "enter deed description" you should be able to turn the bearing and distance labeling as well as the points option off. Just play with the initial settings to get the desired outcome.
Posted : March 4, 2012 7:47 pm
spledeus
(@spledeus)
or just type in PDD
Posted : March 5, 2012 4:04 pm
