Howdy-
The last update of Win 10 completely lobotomized LGO on our PCs, but we do have the option of running Infinity via a floating license. I have attempted to import the LGO data into an Infinity project using a number of different options but to no avail. Does anyone know if there's a converter available? I'm wondering if Leica dropped the ball here on this one, or maybe I'm doing something wrong...
Thank you in advance.
I'm not familiar with LGO, but my accounting software had similar issues with the latest Win-10.?ÿ The solution was to right click on the short-cut for the program, select properties, then select the Compatibility tab and set it to use Win-7 or Win-8 or whatever version that you are confident that it previously worked well with.?ÿ Sometimes you have to try a couple of times before you find the one that does the trick.
Unfortunately, LGO is no longer installed and I do not have administrator privileges to do so... so I'm dead in the water WRT LGO.
