HP 41 CX decimal/comma probload
(@derek-g-graham-ols-olip)
Colleagues-
I must have pushed two buttons at the same time or ?????
At the normal position of the decimal point on the screen, there is now a comma.
How do I get back on track with a period instead of the comma as it is frustrating ?
Thank you,
Derek
Posted : 05/12/2013 3:04 pm
(@cptdent)
HP 41CX Decimal Point restore
Message #1 Posted by Joseph Banki on 22 Apr 2011, 7:06 p.m.
Hi;
After replacing the batteries, the decimal point became a comma, and can not restore it. Also I always used 4 decimals before and that does not come back either. I have the Basics Volume 1 only, and Volume 2 or 3 (?) handles that. Could you help?
Thank you
Joseph Banki enj-banki@sbcglobal.net 281-788-4007
Re: HP 41CX Decimal Point restore
Message #2 Posted by spb on 22 Apr 2011, 7:52 p.m.,
in response to message #1 by Joseph Banki
SF 28
Flag 28 controls the behaviour; when set the separator between the integer and decimal part is a period and the digit separator for the powers of three (if set) is a comma, and when cleared the semantics are reversed.
Posted : 05/12/2013 4:17 pm
(@scott-mclain)
Many languages are like that. I know German's do numbers that way.
Posted : 05/12/2013 4:29 pm
(@surveysc)
Turn off the calculator. Hold down the soft keys A and E and press the on key at the same time. This should reset it.
If all else fails, do a hard reset. Flip over the calculator, pull out the rubber foot that is on the top right. There should be a hoe that a paper clip will fit into. Insert paper clip push slightly and it should reset back to factory settings. It has been a while since I had to do this.
Posted : 06/12/2013 2:29 am
Thank y'all.
Tried it but it still doesn't work properly.
I'll have a go this weekend.
Cheers,
Derek
Posted : 06/12/2013 3:30 pm
(@mark-silver)
My 41CX is long, long DOA. But I remember similar happening.
This link has pictures:
http://www.educalc.net/1178487.page
I now have three HP's that this works on:
Hold down the decimal point.
Continue to hold the decimal point key, while turning on the calculator.
M
Posted : 06/12/2013 6:51 pm
(@roadburner)
User flag 28 controls that. SF 28
Posted : 09/12/2013 8:23 am
Thank you all for your help.
Mark, atta boy !
Do you fix HPs ?
DGG is not frustrated any longer.
It must be approaching at least 30 years that I've used the HP 41CX.
Cheers,
Derek
Posted : 09/12/2013 1:09 pm
