How do I make it so that I can see the "My Places" that I have setup on my PC also on my iPhone.
A sample:
I keep my kmz's on projectwise and am able to open them in google earth through Bentley Field Superviser app.
The only way I have found is to e-mail yourself a KMZ containing them. Then you just open the KMZ from within the e-mail. I usually create a separate KMZ for each project since I do not think you can easily control the individual icons.
Thanks John. I saved my places as a kmz to my dropbox and opened it from there on my iPhone.
That worked.
Does anyone have a "Network Failure" error using Google Earth on Android?
When I try to load a kmz on my android - even ones that I've used before - I get the network failure error.. thoughts?
A large KMZ file like the county property map will lock Google Earth on my S5 with Kitkat
I use an app called KMZ loader.
