Hi all,
Had a curve ball thrown at me the other day. For some reason Trimble Access was exporting incorrect raw data when I'd export a DC10 file, the survey data was out of azimuth and position looked bung too. I then proceeded to export all the file types available including SDR33, csv, and DXF. I found that the DXF and csv files were consistent, but the Sokkia file was way out, in the vicinity of about 80mm for some readings. The control appeared to be on the right azimuth, but the points picked up after each setup were not quite right. Has anybody experienced this with SDR33 file before?
In the past the DC10 files seem to import fine, somethings gone wrong with this particular project. I'll be comparing the DC10 files of previous projects to corresponding csv files tomorrow as a test but I think that they will prove to be spot on. Have any of you had issues with DC10 files in the past, and what do you Trimble users export from Access as raw data?
