Carson "tin" file conversion?
Surveyor NW
(@surveyor-nw)
Ok, it's now time to stake a small parking lot with some interesting grades from the designer for ADA requirements.
As it happens, my old and failing eyes do not seem to locate a way to get Carlson to output a "dtm" file (rather than just using a slow cumberson "dxf" file), to do a surface stakeout for finish grade.
The rock base is a breeze, ONE catch basin and some underground utilities.
Due to the "micro grading" as I call it, they wanted me to put the topo foot on the rod, spray it with "Pam" cooking spray, and ruin a good pair of boots during paving to check grade as they roll it out.... whew!
Back to the question...
How to convert a *.tin file to a *.dtm file for the TSC2 running Survey Pro 5.1.1???
And this is how monday starts... 🙂
Posted : May 13, 2013 11:24 am
RoadBurner
(@roadburner)
We use TDS Survey Link to convert a dxf to a dtm. Not sure how else we would do it tho..
Posted : May 13, 2013 12:57 pm
That is over thinking for an asphalt engineer and quite a funny for a Monday.
They simply set the laydown machine to the correct height for their materials and it is full steam ahead and keep the batch supply acommin'
0.02
Posted : May 13, 2013 1:24 pm
Surveyor NW
(@surveyor-nw)
Even better.... the reason they want "ME" to check it....
the "designer" has a 1.9% slope through a A.C. Valley gutter section not
6 feet away from the only catchbasin, where his grade change is the greatest!
Thank goodness he's a P.E. and knows what he's doing......
My first response was for them to grab their "smart level" and go drag it
around behind the dang roller.....
Hmmmmm I may just stick with that one....... 😀
Posted : May 13, 2013 3:46 pm
Surveyor NW
(@surveyor-nw)
Good point, we just upgraded our Survey Pro (don't do it, it's slow!) so it now produces *.survey files that are only readable by spectra precision survey office.
To be fair, the update will export to a *.raw and *.job file format, which Foresight
DXM does not appear to read very well.....
GOOD POINT though, I could export the*.DXF file, read it into Foresight DXM, then download to the collector!!!!!
Shazammmm! B-)
You guys are the best (of course, that's why your here!)
I'll try this!!
Posted : May 13, 2013 3:54 pm
