My snaps and ortho and all have disappeared from the lower right hand corner where they are normally above the command line box.
Can someone tell me how to get them back?
Thanks
Did Not Know Carlson14 Intellicad Existed
It is probably hiding behind the "Command Line" window.
Reduce the command area in size and reduce the drawing area. You may have to move them around to find what you are looking for, then renest and resize them.
Right now mine reside beneath the command area.
I guess I should be more technical for sticklers...I have Carlson Survey 2014 with Intellicad...and it's not hidden behind my command line. I have no idea where it is, but its stuck on endpoint right now and it's killing me!
Don't know - try "os" or "osnap" command, you could possibly change your snap settings that way in the meanwhile.
If you still have the "READY" section on the bottom left -
hover over that slightly grayer than the command line area
right mouse
select the options you would like in that area (entity snaps, ortho, grid, etc...)
See if this helps:
Having used Carlson Survey in AutoCaD 14 I thought that is what you meant. Carlson 2014 is not Carlson 14.
You should be able to access SNAP options thru the Settings and Toolbar menu.
Type in the command STATBAR....Then type ON.
its always great when you let people know what fixed (or didnt) the problem. I often see problems like this discussed and then no one ever says...that worked and thanks.
Ryan H is a genius...statbar on worked like a champ...Thanks!
