Carlson with Autocad 2015
9 Users
(@djames)
Anyone using it ?
I am sick of intellicad, I have been a good sport, but I have had it . I do not know why Carlson will not go to Briscad .
Posted : February 10, 2015 9:58 am
(@ekillo)
I have it installed on 2015 vanilla AutoCad, but so far have only used it to save drawing down to LDD 2008. I am still in the process of learning Carlson and have not got used to the point blocks and nodes set at an elevation instead of zero like I normally use in LDD.
Posted : February 10, 2015 10:04 am
(@stephen-ward)
I just switched from Carlson 2013 on vanilla AutoCAD 2013 to Carlson 2015 on vanilla AutoCAD 2015 at the beginning of the year. So far I've not found any problems. In fact, Carlson's support for annotative text and AutoCAD's ability to import pdfs as underlays has been worth the price of admission.
Posted : February 10, 2015 10:15 am
> ...and have not got used to the point blocks and nodes set at an elevation instead of zero like I normally use in LDD.
There is a setting for that. In fact, there is a setting for that in LDD.
Posted : February 10, 2015 10:16 am
(@stephen-ward)
There's a switch under the draw points dialog that allows you to insert the points and nodes at zero.
Unchecking this box will bring them in at zero. Typically I insert them at zero, but for topos I find that it works better if they're at their true elevation.
Posted : February 10, 2015 10:21 am
(@j-t-strickland)
Yes, I bought Acad at the end of last year, had the Civil Suite for a while, been using it since then. Before that I used the embedded version of Survey, but missed some of the commands. Intellicad wasn't up to par at that time, but I hear it's getting better. Carlson / Autocad is working fine for me, unremarkable/ no complaints.
Posted : February 10, 2015 10:30 am
(@ekillo)
Thanks
Posted : February 10, 2015 12:11 pm
(@ekillo)
Thanks
(@cptdent)
I am running Carlson Survey 2015 OEM at home and Carlson Survet=y 2015 on top of AutoCas 2014 at work. I find that I orefer the OEM version over all.
Posted : February 10, 2015 12:21 pm
(@djames)
I would go with the OEM version but I have a bunch of home grown lisp routines that I like to use. i do not think they will not work with OEM if I am not mistaken.
Posted : February 10, 2015 12:54 pm
(@j-t-strickland)
yes, sir, you are correct about lisp if it hasn't changed very recently.
Also, correction, I said I got Acad end of last year, should have been year before last, had it a little over a year.
Posted : February 10, 2015 1:41 pm
(@kris-morgan)
I have it with the OEM engine and the only thing I don't like is that it occasionally crashes with mtext open. I can save it but I have to crank the program back up.
Posted : February 10, 2015 1:56 pm
(@stacy-carroll)
We have been using Carlson 2015 on Autocad map 3d 2015 for a couple weeks. Switched from Carlson/Autocad 2012. Smooth transition and not much lost productivity. Carlson is much more stable. Used to crash 4-8 times a day. In all fairness, my computer was probably the issue and not the software. No complaints...
Posted : February 10, 2015 6:36 pm
I can only remember a couple times in the last 5 years or so that Carlson has actually crashed.
Posted : February 11, 2015 8:52 am
(@stacy-carroll)
The computer that I inherited when I went to work there was nearly 10 yrs old. It began crashing anytime I worked with coordinates using the CG commands (die hard C&G user). Later it crashed if I didn't hold my mouth right...
Posted : February 11, 2015 8:18 pm
