Carlson update question.
 RFB
(@rfb)
Carlson 2013 w/embedded ACAD
I just received an update, can I save my customized toolbar before I install the update?
TIA
Posted : May 24, 2013 4:47 am
(@surveyor-nw)
I believe so... check your documentation.... mine saved last time I updated but that was quite awhile ago.
Double check with your software sales folks, they've had quicker than quick answers for me in the past!!
Posted : May 24, 2013 9:13 am
(@ladd-nelson)
I'm not the foremost expert when it comes to CUI/CUIX changes (I'll take the old MNU files any day) and CUIX transfers but it should be possible to save customized toolbars.
At the Command: prompt, type CUI to bring open the Custom User Interface dialog box. Per the instructional notes, you should be able to drag-n-drop customizations in the main application into a new CUIX file, save it, and then open those customizations after installing any updates:
Anything beyond this process and I would defer to the Carlson Technical Support Staff.
Posted : May 24, 2013 12:15 pm
