Is there a way to change the default value of a command in Carlson Survey OEM for example the line command has the following default value-
[Distance/Undo/]:
How would I change the default value to Distance in this instance automatically for each time. Thanks.
Type "D" then "Enter" when you are at that command line. Should stay set to that until you have made your choices. A lot of these options retain the last option until you exit the drawing.
cptdent, post: 365617, member: 527 wrote: Type "D" then "Enter" when you are at that command line. Should stay set to that until you have made your choices. A lot of these options retain the last option until you exit the drawing.
Normally it would retain the last option but for some reason it doesn't with this command on my installation. Could you try it on yours and see does it work.
What command are you running?
RoadBurner, post: 365668, member: 6168 wrote: What command are you running?
It's the line command on the tool bar ,2DLINE on the command line.
The command always give the same prompt on my installation no matter what. Must be in the code.
RoadBurner, post: 365738, member: 6168 wrote: The command always give the same prompt on my installation no matter what. Must be in the code.
Thanks. Looks like it.
