Carlson Survey GIS
allen-wrench
(@allen-wrench)
I have a spreadsheet of points with all kinds of info on the monument found (year, PLS#, GCDB, etc, etc.) in addition to northing/easting and lat/long. All of the fields are the column heading. Is it possible to use this spreadsheet to build a GIS system in Carlson Survey, without having to re-key in all this info point-by-point?
I need a way to keep track of (essentially) PLSS corners and lines, and encode info on each of them. I'm hoping I can do this in Carlson somehow, and be able to share it with ArcGIS users.
Posted : July 24, 2017 9:02 am
jimmy-cleveland
(@jimmy-cleveland)
Yes, you will need to import that spreadsheet into an Access database. The information in the CAD file is linked to the database. I have only linked polygons (closed poly lines) to the database, but I assume that the same can be done with points or symbols.
I am currently using Carlson GIS with Intellicad on a project building a database for a client that currently has approximately 5,200 or so records in it.
You may need the GIS module to do what you are wanting to do.
Posted : July 26, 2017 9:11 am
Bump TTT.
Posted : July 26, 2017 3:11 pm
