Carlson Survey 2008 Points Question
5 Users
(@jimmy-cleveland)
I use the SPT4 block for my point symbol. For those of you who don't use Carlson, or don't recall the block name, it is a circle with a node in the center of the circle.
I often use the Move Point Attributes with Leader to bring my point numbers out from a corner or a feature, to make the point numbers, elevation, and description easier to read.
I generally bring all of my points in on a PTS-SURVEY Layer, and all is good. Once I resolve my boundary, and either set my new corner points, or determine which existing points will be my corner points, I generally change those points to a PTS-CORNERS Layer, and I also put my control or traverse points on a PTS-CONTROL Layer.
It seems like I have to select the circle, the leader arrow, the leader line, and the point number to change everything to the desired layer. If I don't have the leader and arrowhead, I still have to select the point number and the circle to change all of the point information to the desired layer.
I don't have the boxes checked for separate layers. My typical layers that come in when I import points is as follows:
PNTDESC
PNTELEV
PNTNO
PTS-CONTROL
PTS-CORNERS
PTS-SURVEY
I know I can use the field to finish for some if this stuff, but I still want to be able to easily change the points to the desired layer without having to select a ton of entities.
As always, any advice you can provide is very much appreciated.
Thanks,
Jimmy
Posted : June 26, 2013 7:55 am
(@va-ls-2867)
Set up point groups based on your descriptors, you can then select points by group name.
Posted : June 26, 2013 8:22 am
(@roadburner)
> PNTDESC
> PNTELEV
> PNTNO
> PTS-CONTROL
> PTS-CORNERS
> PTS-SURVEY
> Thanks,
> Jimmy
That's why I don't use symbols for my points (SPT4, etc). My points are just one cad entity: a block with a node for snapping to, a circle or triangle or X or whatever, and attributes for Point#, Elev and Desc. Life is good!
RB
Posted : June 26, 2013 10:15 am
(@davidalee)
CTRL-A will turn your group on or off. With group on, you can select any part of the point (desc, symbol, etc) and it will select everything; with group off, you can select individual parts.
Posted : June 26, 2013 11:44 am
(@jimmy-cleveland)
Thanks guys. The grouping worked for my purposes.
Posted : June 26, 2013 2:06 pm
Carlson Survey 2008 Points Question ~ CTRL-A
I love this bar. Thanks David!
Posted : June 27, 2013 6:22 am
