Carlson move point attributes leader arrow
 FLS
(@fls)
How do you turn on the arrow on the leader when you move a point attribute?
CS 2010.
Thanks
Posted : June 25, 2012 4:24 am
(@foggyidea)
in the 2008 stand alone version it's an option under Points>Move Point Attributes With Leader
if you're not seeing a leader then the line could be to short to support a leader, or the arrow size in your defaults may be to small of large...
Posted : June 25, 2012 4:37 am
 FLS
(@fls)
Thanks found it
Posted : June 25, 2012 5:17 am
(@ladd-nelson)
During the prompt:
>Command: movepntleader
>Select Point Label to Move [Options/Restore/Multiple/Group/Number]:
Type o (for Options) to expose the dialog box with various settings. The ability to enable the Draw Arrowhead setting should be there.
Ladd Nelson
Posted : June 25, 2012 6:38 am
(@stephen-johnson)
Thanks.
I just used the info you supplied to adjust some things about that particular function to suit my preferences.
SJB-)
Posted : June 25, 2012 7:14 am
