I have emailed support also.
I have a centerline file created successfully.
I am entering the ROW but cannot find a way to allow the ROW to be curved in certain places like the old highway plans.
Did you make sure to check the follow CL option in the dialog box??ÿ It works fine for me on Carlson 2021.
Another option is to use the 2dpolyline function and enter the station/offsets using the 'cl transparent command.
What I did see in your pictures is the last station you entered in the command was not valid so it did not exit the command properly so the last segment wasn't drawn correct.?ÿ I did see in my testing where it does not handle a change in offset like your map shows where it will increase offset while moving back in station.
Aha, all excellent tips. ?ÿI will look into these when I return to my pc.
Thank you!
I am not finding that...?
@brad-ott?ÿ maybe not an item in 2016??ÿ This is the dialog box after I select the cl file in 2021.
