I am trying to set up a curve table for a plat I'm doing. I have my table looking the way I want, but I can not find where I set the formatting for the curve tags (not sure if Carlson uses that nomenclature, but I'm referring to the C1, C2, C3, etc. labels on the curves). I need to set the layer, the text style, and the text height.
I'm working in Carlson 2020 with Autocad.
Thanks in advance!
Annotate-Annotate Defaults- ARCS ... for your layers
Annotate-Line/Curve Table-Table Defaults ... For Custom Curve Labels
It's not taking the properties that are in your first response.?ÿ Your second response only has settings for the table itself, not the tag. Are you using Intellicad? I'm beginning to think that these routines are set up to work in Intellicad but Carlson isn't really checking to see if they work in?ÿ
Autocad as well.
@blitzkriegbob Yes I am using intellicad.
Actually I see you are correct with the second response, except that also controls the layer. It looked like all the line table settings were on the left side, and the curve label settings were on the right. I now see that I assumed incorrectly, and the upper left is actually the tag settings, and the upper right are the table settings.
Thanks for making me take a longer look at that!
