I cannot get the field to finish to draw a 3d polyline this is with just 3d polylines and 2d and 3d polylines set up in the filed to finish. The points and nodes come with elevations but the linework is all 0 and when I check the properties they are all polylines not 3d polylines. Has anyone else run into this?
Is the dc set up to create a 3D polyline ? ?ÿIt seems like that could fall apart when you went to import the F2F.?ÿ
It??s just an ascii file so I don??t think that would matter
I don't have the 2018 edition but one place to start is I'd confirm that under "additional draw options" under the f2f menu that you have the "locate linework on real Z axis" turned "on" or "by code" whichever is appropriate for your coding.
I missed a check box thanks had points checked but somehow forgot to check linework.
