Carlson 2016 standalone crashed after windows 10 update
Dane Mince
(@danemince)
?ÿRECENT UPDATE OF WIN 10 CAUSES CARLSON TO CRASH ANY SUGGESTIONS ABOUT HOW TO FIX THIS?
Posted : June 16, 2018 9:26 am
stephen-ward
(@stephen-ward)
Off the top of my head, I'd say the Windows update may have killed your Carlson Registration.?ÿ I'd check there, and if it shows as unregistered/expired I'd re-register using OS update as the reason.
Posted : June 16, 2018 11:25 am
just-a-surveyor
(@just-a-surveyor)
Do you have McAfee Virus software? If you do that is the likely culprit. Carlson does not play well with McAfee. I had to uninstall my McAfee because of crashes and now rely solely on the built in Windows defender.
Posted : June 20, 2018 2:11 pm
daniel-ralph
(@daniel-ralph)
I am having the same problem with Microsurvey. Something is triggering the settings to change upsetting the graphics which cause the program to crash or hang. Thankfully I have a maintenance plan and product support is very quick to respond.?ÿ?ÿ
Posted : June 20, 2018 3:22 pm
I recommend that your work computers operate from a cloned harddrive and not be connected to the internet on a daily basis.
Posted : June 20, 2018 9:14 pm
Dane Mince
(@danemince)
that is a great idea and gets rid of the forced update issue. Most of these updates seem only designed to funnel the user into having to buy something else....
Posted : June 22, 2018 9:19 am
cptdent
(@cptdent)
The problem is that everytime Windows 10 updates (almost a daily event) it erases your product registration, so you have to reregister after every update. I THINK?ÿthat the problem has been corrected in Survey?ÿ?ÿ2018.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ
Carlson 2016-2018 with IntelliCAD 8.x
  • Compatible with 32 or 64 bit Windows Vista, 7, 8, 8.1, and 10
  • For hardware requirements, see Carlson 2013-2015* below
Carlson 2013-2015* with IntelliCAD 7.2
*Starting with 2013 build 130120
Intel?? Pentium?? 4 or comparable (minimum), Intel i7 or at least Intel i5 or comparable (recommended). Due to the variety of processors on the market, one can use cpubenchmark.net/cpu_list.php to do comparative analysis. While the overall processor score matters, the single thread performance is of the most interest.
  • 32-bit Windows 7-8.1: 1 gigabyte (GB) of RAM minimum for, 4 GB recommended.
  • 64-bit Windows 7-8.1: 2 GB of RAM minimum for, 8+ GB recommended.
  • Windows Vista: 1 GB of RAM minimum, 4 GB recommended.
  • Windows XP: 512 megabytes (MB) of RAM minimum, 2 GB recommended.
Graphics card compatible with OpenGL Version 1.4 or higher:
  • Recommended are desktop graphics level discrete (not integrated cards like Intel HD) graphics cards.
  • Preferably Nvidia Geforce due to their more consistent driver support.
  • Discrete ATI/AMD cards will be adequate, but ATIƒ??s driver support has been spotty and user is frequently deferred to the computer manufacturer for support.
  • Professional Nvidia Quadro cards are not currently recommended due to driver issues.
  • Powerful gaming cards are not required and probably would not provide as much benefit as investment in more memory or better CPU
Carlson 2012 and earlier with IntelliCAD 7.1 and 6.x based products
  • Windows?? XP, Windows?? Vista, Windows?? 7
  • Intel Pentium?? or more powerful processor
  • 64-bit machines are supported, but application itself is 32-bit
  • 1 GB RAM (minimum), 4 GB recommended (for complex drawings)
  • 400 MB of free hard disk space (1.2 GB Total, see Note above)
Learn more information about?ÿIntelliCAD.
AutoCAD??
Please visit the AutoCAD System Requirements page for current specifications which are subject to change without advance notice.
Please visit the Autodesk summary of the Operating system compatibility for AutoCAD (Autodesk Bulletin TS14078105) for historical references between AutoCAD and its supported operating system(s).
Please see Note above for hard disk space requirements for the Carlson application.
Embedded AutoCAD?? OEM Engine
Carlson solutions based on AutoCAD 2018 Embedded
Takeoff R10 / Survey OEM 2018
Please note the CPU compatibility below: older AMD CPUs like Athlon XP+ do not support SSE2 technology and can not run Embedded AutoCAD 2018 products.
  • Microsoft Windows 10 (64-bit only); Microsoft Windows 8.1 with Update KB2919355 (32-bit & 64-bit); Microsoft?? Windows?? 7 SP1 (32-bit & 64-bit)
  • 4 GB RAM (minimum), 8 GB (recommended)
  • 2 GB free disk space for installation
  • 1360 x 768 (1920 x 1080 recommended) with True Color
  • Windows Internet Explorer?? 11 or later
  • Install from download or DVD
Carlson solutions based on AutoCAD 2013 Embedded
Takeoff R6, R7, R8, R9 / Survey OEM 2013, 2014, 2015, 2016, 2017
Please note the CPU compatibility below: older AMD CPUs like Athlon XP+ do not support SSE2 technology and can not run Embedded AutoCAD 2013 products.
  • Windows?? 8 and 10 Standard, Enterprise, or Professional edition (8 requires installation of AutoCAD LT 2013 Service Pack 2); Microsoft?? Windows?? 7 Enterprise, Ultimate, Professional, or Home Premium edition (SP3 or later) with an Intel?? Pentium?? 4 or AMD Athlonƒ?› dual-core processor, 3.0 GHz or higher with SSE2 technology.
  • 1 GB RAM (minimum), 8 GB (recommended)
  • 1.4 GB free disk space for installation
  • 1,024 x 768 VGA display with true color
  • Internet Explorer 7.0 or later
Carlson solutions based on AutoCAD 2010 Embedded
Takeoff R4, R5 / Survey OEM 2010, 2011, 2012
Please note the CPU compatibility below: older AMD CPUs like Athlon XP+ do not support SSE2 technology and can not run Embedded AutoCAD 2010 products.
  • Microsoft Windows 7, or,
  • Windows Vista, SP1 or later (Enterprise, Business, Ultimate, Home Premium) operating system, with,
  • Intel Pentium 4 processor or AMD Athlon dual-core processor, 3.0 GHz or greater with SSE2 technology
  • 850 MB free disk space for installation
  • 1024 x 768 VGA display with true color
  • Microsoft Internet Explorer 7.0 web browser or later
  • DVD drive
Or
  • Microsoft Windows XP Professional or Home Edition operating system (SP2 or later), with,
  • Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or greater with SSE2 technology
  • 512 MB RAM
  • DVD drive
Carlson solutions based on AutoCAD 2007 Embedded
Takeoff R2, R3 / Survey OEM 2007, 2008, 2009
  • Windows Vista, or,
  • Windows XP Home or Professional SP1 or better, or,
  • Windows XP for Tablet PC SP2, or,
  • Windows 2000 SP3 or better
  • Pentium III 800 minimum, Intel Pentium IV recommended
  • 512 MB RAM
  • 550 MB free disk space for installation
  • 1024 x 768 with True Color
  • Microsoft Internet Explorer 6.0 SP1 or higher
  • CD-ROM drive
  • Mouse, trackball, or compatible pointing device
Carlson solutions based on AutoCAD 2004 Embedded
Takeoff R1 / Survey OEM 2004, 2005, 2006
  • Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), or,
  • Windows 2000, or Windows NT 4.0 (SP6a or later)
  • 256 MB RAM
  • 300 MB free disk space for installation
  • 1024 x 768 VGA with true color (minimum)
  • CD-ROM drive
?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ
  • (An upgrade from 2016 to 2018 is $995.)
Posted : June 22, 2018 5:34 pm
