We are using Carlson 2004 Field to Finish for our point and linework procesing. I am having an issue with the node and the symbol. They want to be attached to one another, even though they are on different layers. I can turn the symbol off and leave the node on and vise versa. But I cannot delete either one individually. Nor can I rotate or scale just one of them. Pretty much the only thing I can do with them separately is on/off and freeze/thaw.
It must be a setting somewhere because I opened an old dwg that had them separate and re-ran the field to finish and it attached them together.
Any suggestions.
If in Autocad, Options-Selection-Object grouping (turn it off)
CC
Use "Ungroup" to separate the symbols from the points if they are on separate layers.
Thank you all. So simple, yet when you don't know where it is, so frustrating.
