AutoCADD question in Carlson Survey 2013
Lloyd L Tolbert
(@lloyd-l-tolbert)
I think I could of titled this question better earlier. Sorry about the re-post...
I am in using Carlson Survey 2013 with built on AutoCAD. A setting has changed somewhere and I am only able to select one object or group of objects at a time. If I try to select multiple objects individually or several groups, it won't let me. arrrggghhh. This has to be an easy fix, I'm just not seeing it. Would appreciate some help. Thank you, LT
Posted : January 12, 2016 8:52 pm
jimmy-cleveland
(@jimmy-cleveland)
type Pickadd (might be pickad)
if the value is zero, change it to one, if it is (1), change it to zero
Posted : January 12, 2016 8:56 pm
spledeus
(@spledeus)
Carlson -> Settings -> System Variable Editor
It gives a little description too: Controls Additive Selection of entities 0=Disabled, 1=Enabled
Posted : January 12, 2016 9:12 pm
Lloyd L Tolbert
(@lloyd-l-tolbert)
Mr. Pickadd, Genius... Got it... Thank you, LT... & you also Mr. Spledeus
Posted : January 12, 2016 9:41 pm
