I think this is a "0" or "1" toggle somewhere. It allows the user to select an object, then enter the command (instead of just the more common sequence: enter command, then select).
Example:
Erase command, select object.
I want to also: Select object, Erase command.
Thanks
Posted : 25/02/2015 8:06 am
PICKFIRST
Posted : 25/02/2015 8:24 am
Bingo. Thank you
Posted : 25/02/2015 8:28 am
> Bingo. Thank you
That variable can also be set by checking the "Noun/verb" selection mode under the Selection tab of the OPTIONS dialogue.
Posted : 25/02/2015 9:02 am
Also under Options - Selection - Noun/Verb Selection
Posted : 25/02/2015 11:44 am
