AutoCAD
8 Users
I assume "Auto" stands for automatic.
It's not automatic.?ÿ There is no "draft the survey" button.
I imagine a real AutoCAD would draft the survey, make all the decisions on what to hold, what to reject, where to set missing corners, etc.?ÿ It would even submit the survey to the County Surveyor's AutoCAD which would automatically return comments which the Surveyor's AutoCAD would address automatically.?ÿ No intervention by humans necessary.?ÿ May as well get a beer and a rocking chair and retire, the AutoCAD does it all.
Posted : January 23, 2019 9:49 am
(@jeran-hopfe)
Considering itƒ??s built for engineers, maybe thatƒ??s why?
Posted : January 23, 2019 10:23 am
(@gromaticus)
Every once in a while I have a client state that having the computer draft the plan should be easy: all I have to do is "push a button."
Posted : January 23, 2019 10:48 am
(@bradl)
AutoCAD does draft about 50% of my product.?ÿ I couldn't image creating contours by hand, especially from a point cloud.?ÿ Could you image having to draw an alignment, profile grid, then create a profile from the existing contours you hand drew, just to have an engineer tell you they wanted it at at different scale?
Posted : January 23, 2019 11:13 am
(@squirl)
It's not "automatic" but it's getting dang close with automated linework, contours, dynamic objects and so on.
Still need someone at the keyboard to cuss and slam the mouse right before it crashes though, so we'll be employed for a while.
Posted : January 23, 2019 1:47 pm
(@true-corner)
Posted by: Squirltech
I'm still doing point and click.?ÿ Dang I'm behind the times.
Posted : January 23, 2019 8:58 pm
(@wa-id-surveyor)
Definitely not automatic but for topographic surveys it can get you 80% of the way there with a good field to finish process.
Posted : January 24, 2019 8:17 am
(@squirl)
Posted by: True Corner
You know you can draw by point ranges, right? Activate the LINE/POLYLINE and then type 'PN. Enter the point range, separate with commas and hit ENTER. This will draw each entity based on the point range entered. If nothing else, it's quicker than the point/click method you mentioned.
Posted : January 24, 2019 9:39 am
Make sure OSNAP is off when using 'PN or expect weird results.?ÿ There's another snap thing in there too that I discovered which was causing 'PN entries to miss the point entirely.
Posted : January 24, 2019 9:48 am
(@squirl)
Posted by: Dave Karoly
Weird, I haven't had seen this issue. Good to know.
Posted : January 24, 2019 10:43 am
I think I discovered "3D Object Snap" was causing the issues...turning that off solved a lot of problems.
I'm using Civil3D 2016.
Posted : January 24, 2019 10:50 am
(@david-livingstone)
Auto stands for what it does to your bank account, automatically drains it every year.
Posted : January 24, 2019 10:52 am
