Is there a way, in CADD, to set nodes on a line 599.96 feet long; at 12 equal points?
TIA
Dugger
Posted : September 2, 2014 9:04 am
(@jimmy-cleveland)
In plain autocad, I think the command is divide. In Carlson, I think it is interpolate points along entity, under the cogo pulldown menu.
Posted : September 2, 2014 9:21 am
(@azweig)
Divide is the command you want in plain AutoCAD. It sets AutoCAD points, you might have to type "ddptype" after using the divide command to see the points
Posted : September 2, 2014 10:40 am
(@kevin-hines)
Lost that mystical 0.04' again! Where did it go this time?
Posted : September 2, 2014 10:44 am
Not to bad for an 1890 plat, eh?
Posted : September 2, 2014 10:52 am
(@spledeus)
just for fun
Rather than DIVIDE you can run the geometry:
Draw a line perpendicular to the line in question.
Move it to the endpoint of the line in question.
Offset it 12 times by the same amount. (Array)
Scale with reference from endpoint to endpoint (Align)
Or you can use concentric circles, polygons or anything else.
I always dream about going back in time and showing CAD to Euclid... His mind would be blown away and my name would be on the Elements: Thaddeuseun Geometry.
Posted : September 3, 2014 2:18 pm
just for fun
A couple of times, my old boss would leave a complex geometry problem on my desk. I would solve it in about 5 minutes using CADD. I think the first time, he thought I was a genius, the next time he asked to see my work...I told him I was too busy for that.
Posted : September 4, 2014 10:42 am
