Is it just me?
Is it just me?
5 Users
The color change that normally occurs when you view a thread is not staying that way for me. That is, I view a thread and those posts change color. I think I'm staying connected, yet when I check back in an hour later everything has returned to the original color. Noticed this late yesterday and it's continuing this morning.
Posted : January 19, 2012 7:51 am
Must be some toggle somewhere on your end. Mine works fine.
Posted : January 19, 2012 7:57 am
(@perry-williams)
yes, it's just you.
Posted : January 19, 2012 9:50 am
Wendell
(@wendell)
Admin
If you do any cookie cleaning or have changed any software settings to perform automatic cookie cleaning, then that may be the issue. But it's definitely a cookie issue.
Posted : January 19, 2012 10:14 am
(@eddycreek)
I'm having an issue the past few days where the site opens up, but sometimes just the header at the top shows up but no posts. Hit refresh and then it usually loads. Especially bad when I click on a post, nearly always get that and the yellow triangle at the bottom, when I click on it I get this.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; InfoPath.1; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET CLR 2.0.50727; .NET4.0C; .NET4.0E; .NET CLR 1.1.4322; AskTbARS/5.13.1.18107)
Timestamp: Thu, 19 Jan 2012 18:37:41 UTC
Message: Syntax error
Line: 1
Char: 1
Code: 0
URI: http://static.ak.fbcdn.net/connect.php/js/FB.Share
Line: 1
Char: 1
Code: 0
URI: http://static.ak.fbcdn.net/rsrc.php/v1/yG/r/YYZrixQZaWZ.js
Usually can click on refresh and the posts show up. This is on a different computer than the one I was having trouble with over the weekend, different location. Just happens on this site. Any ideas?
Posted : January 19, 2012 10:40 am
OK. I just logged out. Then logged back in. It now shows this thread in red, which is the only thing I looked at just a couple of minutes ago. Everything else I have looked at earlier today or before is blue, as if unread.
Posted : January 19, 2012 11:34 am
