Has anyone used the x90 opus with other receivers especially the sokkia stratus.
I am having elevation problems. The correct offsets. Any help would be great
Thanks
I use my two X-90 OPUS receivers with my Topcon Hipers on a regular basis. I use Topcon Tools for my main processing software.
I have run into elevation issues when using GNSS Solutions.
What software are you using?
Sokkia spectrum survey 4.22
I do not have any experience with that software.
What types of differences in elevations are you seeing? I was having an even 2 meter bust sometimes when I was importing rinex files into GNSS Solutions.
2 decimeters+/-
It sounds like your SW is not modeling the antenna correctly. That 2 dm should be close to the distance between the ARP and the L1 phase center. Use OPUS RS to check it then Adjust your measure up if necessary. I prefer to do my processing in OPUS Projects when I am mixing receivers and antenna.
Thanks Steve will try it. It puts me above the machine.
Steve
It is the L1 + L2 that was the difference. It is the very top of the antenna 🙂
Thanks Doug
