What is the best wa...
What is the best way to setup an external radio UHF antenna for a GNSS Base
12 Users
(@billyandriam)
Trusted Member Registered
@david-livingstone Cool. So if I understang correctly, you fasten the tribrach in place with the tribrach screw. Correct?
Then how do you put the range pole? Directly on the tribrach? Don't you need some kind of tribrach adapter first in order to mount the range pole on top?
Do you think these kits from TRIANGL would work? I am just worrried if the tribrach adapter won't be strong enough and would maybe break in case of high wind bursts if I set up a 3m range pole +UHF antenna on top of it.
tribrach triangl kit 2
Posted : 16/06/2023 4:01 am
(@billyandriam)
@james-vianna I really had to look it up because I couldn't believe ! Is that this Extend radio arm from TRIANGL?
triangl antomini kit2 1 2 RS2
I am very curious right now. From what I see, this is not actually an external radio but you are still using the internal one (probably1-2W) and boosting the coverage by extending the antenna out? Right? Is the gain in performance noticeable? Sorry if it seems like a dumb question... Emlid claims a RTK coverage of 8km radius with the original radio so I am very eager to know.
I am planning to buy the Emlids in the future for drone surveying/Photogrammetry so I am quite glad I learn something new about these.
Posted : 16/06/2023 4:13 am
(@billyandriam)
@tom-bushelman Thanks for taking the time to share your setup Tom. What do you use to fasten the level rod in the center of the tripod? Isn't there any wiggle room for it to move around otherwise?
Posted : 16/06/2023 4:16 am
(@james-vianna)
Honorable Member Customer
@billyandriam
Yes i use that holder also but for the 25' rod i use this
20230616 082309
The internal radio is like a 0.1 watt and the stock antenna is junk. With the system i use, it more than triples the range through the woods. 3000' to 5000'.  8km is under perfect conditions like across a lake. Alternative if cell service is available is to use the free emlid castor.
Posted : 16/06/2023 4:30 am
(@tom-bushelman)
There is a bit of wiggle room and is not fastened at the top of the tripod but if strapped to a deep cycle battery on the ground, it is pretty stable.
Posted : 16/06/2023 9:07 am
(@jitterboogie)
Famed Member Customer
"   "  Rovers comments
if no extra tripod, just take range poles for the antenna mount( 3-5 depending on length of antenna wire) assemble, and then take 4 lath and hammer into the ground about a foot or so.
Wrap with flagging or tape or a ratchet strap wrapped around to squeeze the love into it,
 bomber and always with the usually found gear in a survey rig.
  This obviously doesn't work in rock terrain.
Additionally, if using a tall set up, you can run the range poles with a sharp tip into the ground then suspend the full size battery(blue top or yellow top OPtima ) from the top of the trip pod, its never going anywhere, unless its a tornado or a hurricane, ill post a photo of my 80mph gusting wind set up, never had one blow over yet.
Posted : 16/06/2023 9:49 am
(@lukenz)
Honorable Member Registered
@billyandriam
Unless it is quite windy I don't fix pole to legs as not usually much space for it to roll around in centre of tripod. I do try stab the pole into the dirt below by twisting it and if very windy use a short cam buckle tie down to fix it to the legs.  I also use the cam buckle tie down to hold the pole against a fence post if one is nearby the base setup.
Posted : 16/06/2023 11:19 am
(@lukenz)
ratchet strap
I've found I carry one of these to encourage smaller trees/branches/shrubs offline for traversing where you have limited sight line options.
Posted : 16/06/2023 11:22 am
Illustrious Member Registered
IMG 7577
Posted : 18/06/2023 9:37 am
(@vince64)
Active Member Registered
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Bonjour Billy,</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;">J'utilise, ou plutôt j'utilisait exactement le même type de GNSS LEICA que toi avec exactement les mêmes radio.</font></font></font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Cependant je pense avoir un problème avec mes interfaces ( références et rover ) et du coup les deux ne communiquent pas entre eux.</font></font></font></font></font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Je mets quelques photos de mon interfaces référence au cas ou vous trouveriez une erreur dans la configuration de mon interfaces.</font></font></font></font></font></font></font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">J'espère que vous arriverez à identifier mon erreur dans ces quelques pages.</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;"><font style="vertical-align: inherit;">En vous remerciant par avance.</font></font></font></font>
Posted : 08/05/2024 5:19 pm
(@billyandriam)
Salut Vince64, je parle français mais je vais écrire en anglais car il s'agit d'un forum anglophone et pour que la discussion pourrait bénéficier à quelqu'un d'autre. Je veux bien t'aider mais il faudrait que tu crées une nouvelle discussion et non par ici. Ta publication aurait plus de visibilité ainsi et il y aurait plus de personnes enclin à t'aider.
Sinon tu pourrais aussi m'écrire en message privé et je verrai ce que je pourrais faire. Merci
Posted : 13/05/2024 10:42 am
(@vince64)
Hello Billyandriam
Thank you for these instructions, which I followed.
I just created a new discussion in which I posted photos of the configuration of my gx1230 GG and my RX1250 WITH pacific crest pdl GFU15-2 radio.
If you can take a look and see what's not working that would help me.
Thanking you in advance.
Sincerely
Posted : 27/05/2024 12:02 pm
Share:
