Hi everyone,
I cant seem to find how to enable the NMEA stream on my Trimble R4 rover in trimble access (juno T41)
I heard its supposed to be in the survey style configuration but there is nothing related to NMEA anywhere there...
Does R4 has a webGUI?
Thank you for your help guys!
It's at the very bottom when you first go to edit the survey style:
Only setting I know that would hide NMEA outputs would be if you had the rover set to a FastStatic survey style.
So i think i dont have nmea stream listed because my trimble access is from 2014...
Is there any way to enable it from another way than trimble access? Webgui?
Maybe "Trimble GPS Configurator" ---> Serial Outputs?
https://manualzz.com/doc/22884867/configuring-the-trimble-r8-to-output-serial-data
download
https://kb.unavco.org/kb/article/trimble-gps-configurator-all-versions-331.html
