TPS to Rinex
(@landman)
Estimable Member Registered
I did a 40 minute static session the other day using a Topcon HiperLite receiver, sent the file to OPUS-RS and received the results. But when I try to convert the tps file to rinex to import into GNSS Solutions, I get a message that it is an invalid raw data file. I've done this literally hundreds of times but today it doesn't work. Any suggestions?
Thanks
Posted : 15/09/2017 8:38 am
(@landman)
Followup to first post - I get a message in GNSS Solutions "Error- Ephemeris file for (filename) not found, cannot import (filename). Invalid raw data file". Has something changed on the Hiperlite to not get the ephemeris file or is something getting lost when converting the Topcon file to Rinex in Topcon tools? What am I doing wrong? Thanks for any help.
Posted : 25/09/2017 5:10 am
(@totalsurv)
Noble Member Registered
Have a look at this thread, it may be related
https://surveyorconnect.com/community/threads/topcon-tools-pp-error.331613/
Posted : 25/09/2017 7:04 am
(@landman)
Totalsurv, post: 448227, member: 8202 wrote: Have a look at this thread, it may be related
Thank you very much, this gives me a solution.
Posted : 29/09/2017 7:41 am
(@spyropas)
Eminent Member Registered
I had the same problem and i think the cause is the folder in dropbox that i imported all the rinex to the project
Posted : 07/03/2019 2:16 am
Share:
