I did not try it but is it possible to setup the base to broadcast RTK correction via External Radio and internal UHF modem? Possible application is broadcasting RTK correction in two different protocols like Leica 4G and RTCM 3.2. Leica Smartworx Viva simulator allows it.
Any experience?
Posted : 29/04/2022 3:02 am
I don't think it is possible.?ÿ As I recall, while you can set up 2 different outputs, you can only use one at a time.?ÿ I tried to set mine up to broadcast on internal UHF and GSM simultaneously without success on a GS16.
Posted : 07/05/2022 6:14 am
@john-putnam I also tried it two days ago with same result as yours.
Posted : 09/05/2022 2:01 am
