ProMark 3 Older Fir...
ProMark 3 Older Firmware
11 Users
2 Reactions
tabbi
(@tabbi)
Posted : April 25, 2025 10:42 am
tabbi
(@tabbi)
@alan-cook
Hello Cook, if you are working in static mode, it would be better to convert your files to RINEX. And since the date is shifted by 1024 weeks, you need to correct the dates in your RINEX files (just the dates, not the time). To do this, I made a video (the result is 100% — I tested it). Here is the link.
https://drive.google.com/file/d/1DCXs7eGNvfJXRh1_i2x2I4q341WNZZ2_/view?usp=sharing
Posted : April 25, 2025 12:16 pm
tabbi
(@tabbi)
@markleedsuk hello Mark ,it's not necessary to convert to rinex if you use BASE and ROVER the résults  in post process is correct  , there is a video how correct date> https://drive.google.com/file/d/1DCXs7eGNvfJXRh1_i2x2I4q341WNZZ2_/view?usp=sharing <
Posted : April 25, 2025 1:58 pm
alan-cook
(@alan-cook)
@tabbi
Could you be so kind as to enlighten me on the procedure for uploading the files into the ProMark 3 receivers?
Alan
Posted : May 2, 2025 4:47 pm
tabbi
(@tabbi)
@alan-cook
Preparation of the SDCard:
1. Insert the SDCard in the card reader on your desktop. Format it in FAT32
2. Copy in the root directory of your SDCard the following files:
   ProMark3V120.txt
   P006.txt
  1. And all the following directories:
    \ BALDURP006
    \ ProMark3V120
  1. Insert the SD card in the ProMark3 RTK.
Reloading the boot, OS f / w GPS and F / W
Turn on PM3
Double click the Utilities icon and launch AUTOLOADER
In the new window, select the ProMark3V120.txt and click OK
At the end of the load, close the window "Loading ... Success"
Start again AUTOLOADER
Select the file P006.txt and click OK
At the end of the load, close the window "Loading ... Success": PM3 will reboot automatically.
When PM3 has rebooted, do a Restore Factory Setting by pressing keys LOG IN + + MENU
Posted : May 3, 2025 8:26 am
tabbi
(@tabbi)
   ProMark3V120.txt
   P006.txt
    \ BALDURP006
    \ ProMark3V120
Turn on PM3
Posted : May 3, 2025 8:28 am
alan-cook
(@alan-cook)
@tabbi
Thank you very much.
Alan
Posted : May 3, 2025 11:26 am
tabbi
(@tabbi)
Up until now, everyone who installed P006 has managed to get their GPS working again. Maybe you need to downgrade from OS F/W 2.16 to OS F/W 2.12. You should probably post your issue on the forum. Good luck!
Posted : May 12, 2025 7:37 am
Orestis
(@orestis)
Hello, my name is Orestis and i am a civil engineer from Greece. I am experiencing the same issue with my Promark 3 receiver. I have downgraded to P006 and installed the Mobile Mapping 1.20 but my issue persists. Is there anything else i could try? Has anyone else tried the steps mentioned but still have the same issue? I would very much appreciate any help.
Posted : May 12, 2025 7:45 am
nikoszan
(@nikoszan)
@aelefth
Hello
I also have the promark3 rtk
With the firmware P006 it works with wrong dates but not the rtk
Can I have the firmware P008?
My Email [email protected]
Thank you
Posted : May 17, 2025 12:22 am
Yannis - Island of Skopelos - Greece
(@asterya)
@tabbi
Dear Tabbi ,
I sent a colleague the link you sent me, who could not open it because he has no access. Is there a code to use?
I haven't installed it yet.
In fact a fellow engineer who installed it, after contacting you, called Orestis Apostolou, reported to me that he saw no improvement in opening satellites!
However, if there is a password to open the link, please send it to me!
Best wishes from Skopelos Greece ,
Yannis Asteriadis
Posted : May 17, 2025 2:13 pm
Orestis
(@orestis)
Dear all,
I repeated the steps provided by @Tabbi and downgraded both firmware (P006) and Mobile Mapping 1.20. After exposing my rover to an open space for at least 3 hours, satellites displayed in the surveying screen.
Date is still depicted as of 1024 weeks in the past, but after converting raw files to RINEX (Following Tabbi's video), i was able to correct the dates, import the file to GNSS and extract correct coordinates.
Best Regards,
Posted : May 21, 2025 4:33 am
Pineda2024
(@pineda2024)
Saludos a todos desde Guatemala, yo tengo 2 PM3 RTK con sus discos, y tengo otro PM3 solo como estático. (Se hizo la actualización al P006 y MM1.2 del PM3 normal y recibe satélites, con la diferencia horaria y fecha incorrecta)
Subiré los archivos de los discos de los RTK a Google Drive de los discos, para ver si alguien puede encontrar la solución.
Dejo acá el enlace:
removed link
removed link
Posted : June 9, 2025 8:11 pm
Herivelto
(@herivelto)
@tabbi eu sou do brasil e estou enfrentado o mesmo problemas com os meus promark3, vi que tem uma solução e gostaria se tiver a gentileza de me enviar por email ou link, para que eu possa testar.
Obrigado
Herivelto
Brasil
Posted : March 1, 2026 9:21 am
salpsco
(@salpsco)
@tabbi
please how are you? Kindly assist and provide me with the firmware for Promark 3 P006 and the Mobile Mapping 1.2
Posted : April 27, 2026 5:10 pm
